Boost ZTE Max XL windows driver issue...
AlloyCowboyAlloyCowboy Posts: 7 ✭✭✭✭
Hello. I love my new phone. but when I connect the usb cable to my windows 7 pc, it allows me to access a driver directory on the phone. I install the windows driver and even reboot, and I just reconnect to the same driver directory. it even tells me the driver is installed when I try to reinstall it, thinking it is a corrupted install. what is going on??
  • AlloyCowboyAlloyCowboy Posts: 7 ✭✭✭✭
    I am just looking to transfer videos from my phone to my pc for video editing.
    hi, @AlloyCowboy , When you connect the phone to your PC, you should see on the notification area for the usb setting. you can tap on it and select MTP. Then you can just open up Windows explorer and see the phone appears there where you can drag files to your pc.
