My vote is for B, and instead of "History" I would consider renaming that dialog to "Preset". Then the Preset value could change as the user initialized the countdown with different times, or alternatively have it simply provide a few slots that the user can define and not a "dynamic" list based on usage). "History" would be more applicable to a stopwatch function where you wanted to see the "history" of recent count-ups.
Not only was it not immediately obvious to me what those history/preset values were on the screen in A until I got the context by looking at B, I couldn't immediately tell the unit of measurement... 00.10.00 could mean zero minutes.ten seconds.zero centiseconds, or zero hours.ten minutes.zero seconds .
edit: one can assume the format of the presets in A matches the pattern at the top of the screen, I just didn't get there until the third look at it, maybe because I'm used to timing shorter events in seconds instead of minutes for something like cooking. I guess it depends on the reader's behavior and regular use cases for a timer when they first look at it.
I picked b because if you needed to look back on something you can
A. It is a clean simple design.
The three adjustable presets would be ideal. I'd set four minutes for when I cook steak, ten minutes for most pastas, and a one-hour timer for my afternoon nap! xD
Design A
I chose A, just seemed cleaner.
