Re: PHONE NOT CHARGING
Hi, am trying to charge my phone, battery indicator is blinking as if it is charging but the percentage is just the same.
  • jasonscarterjasonscarter United StatesPosts: 1,889 ✭✭✭✭✭✭✭✭
    Using official charger and cable that came with the phone? Stock software it custom ROM? Have you rebooted? Does it say charging on lock screen?
    @omuya, I see you are from Kenya. Any chance you could provide the make, model, and build number of the phone you are using? Thanks!
  • razor512razor512 United StatesPosts: 2,657 ✭✭✭✭✭✭✭✭
    If you get a chance, also consider running 3C toolbox. https://play.google.com/store/apps/details?id=ccc71.at.free&hl=en
    After installing and launching the app, click on the expert mode option.
    Once in expert mode, click on "Battery Mgr"
    The first time entering that section, will run you through a setup wizard.
    The most important aspect of the setup, is selecting the right current source. Select "Reverse uA"
    Once there, it should show you how much power the device is using, as well as how fast it is charging when connected to the charger.
    Check if it is actually charging the battery.
