Screenshots
keleigh_siobhan1962keleigh_siobhan1962 United StatesPosts: 2 ✭✭✭✭
At the risk of sounding like a complete idiot I'm going to ask, does the ZTE Blade X have screenshot capabilities? I have read everything I can't figure it out. :blush:
Best Answers
    Accepted Answer
    @keleigh_siobhan1962 I don't have that phone so if there isn't any unusual or special method to take a screenshot in the settings then just try pushing the power button and the volume down button at the exact same time. You might have to hold them for a second or two.
  • keleigh_siobhan1962keleigh_siobhan1962 United StatesPosts: 2 ✭✭✭✭
    Accepted Answer
    I can't believe it was that easy! I feel foolish 😳😀. Thank you.
  • ironbaybeedollironbaybeedoll United States Posts: 4,627 mod
    @keleigh_siobhan1962 This works for most Android devices. There may also be a gesture that does it for you as well, it is not available on all devices, and I don't currently have the Blade X to check for you. However, if available it would be listed in settings under Gestures & motions, three-finger pinch for screenshot. You would simply enable both of these.
