Encryption Unssuccessful Error
jabbacksjabbacks United StatesPosts: 8 ✭✭✭
Hi guys...
New in here... I have ZTE Grand X Z777 with the following error:
Encryption was interrupted and can't complete. As a result, the data on your phone is no longer accessible.
To resume using your phone, you need to perform a factory reset. When you set up your phone after reset, you'll have an opportunity to restore any data that was backed up to your Google Account.
Well anyways.... I tried factory reset thru recovery..... Flash from cache and still end up with the above error. Is there a way I can recover the phone and boot it out of this error?
In SP Flash, when I press the download button, it just sits there without doing anything. Loaded scatter file and the All in one binary file that came with the bundle.... Firmware & SP Flash tool.
Thanks!
  • jabbacksjabbacks United StatesPosts: 8 ✭✭✭
    Why didn't you just go to the main settings and factory reset the phone @jabbacks?
    @jimlloyd40 .... phone cannot go past the error... it stays there....
  • samsamhasamsamha United States Posts: 2,281 ✭✭✭✭✭✭✭✭
    hi, @jabbacks
    It sounds to me that possibly there maybe some data corruption during the encryption process. In this case, I would say try to clear the cache a few times and also do the factory reset in the recovery for a couple of times ,then see if the device is able to boot normally. if not, you may need to contact support (if it's still under warranty) to have the device replaced.
    @jabbacks I don't understand where you said that you factory reset through recovery..... Flash from cache?
    @jimlloyd40 .... Under the error message, there is a Reset Button.... When you click it, it automatically goes into recovery mode....
    edited April 17, 2018 8:31PM
    Here it is
    That is where it stops... Cannot go to main screen or anywhere!
    edited April 17, 2018 8:35PM
    @samsamha.... phone is out of warranty! Tried several times factory reset/clear cache.... it goes back to same error!
    edited April 17, 2018 11:26PM
    There you go.... @jimlloyd40
    Well..... any solutions or we all hit da wall????? hehehehe
