Pokemon go
pearcedpearced United StatesPosts: 1
If you play Pokemon go this phone is suddenly incompatible with the new update. I'm incredibly dissatisfied as I've only had the phone a month and it was working fine until today when Pokemon required an update. I sure hope that this gets resolved
  • samsamhasamsamha United States Posts: 2,330 ✭✭✭✭✭✭✭✭
    edited April 18, 2018 7:01PM
    i don't think this is an issue with the phone but rather is the software update that got pushed out by the game maker. When look at the playstore reviews, it seems that many people are facing the same issue with the latest update across multiple devices (oneplus, pixel 2 xl, etc).
  • jasonejasone United States Posts: 2,118 ✭✭✭✭✭✭✭✭
    I generally play Pokemon Go on my other phone but I just installed it on the Blade Z Max and it is working fine. What software version are you using on the Blade Z Max and which version of Pokemon Go are you using?
    If it is this specific version of Pokemon Go maybe you could try using an older version from APKMirror. Here is a link to all variants that might help.
    I loaded it on my Blade Z Max as well and had no major issues.
