ZMAX PRO System Update error
gxjenkinsgxjenkins Tampa, Fl.Posts: 4 ✭✭✭
I have a zmax pro with Android version 6.0.1, Build Z981V1.0.0B21
Just realized it today that when I do a System Update I'm getting an error msg that says:
Please check your Network connection
Metro is no help at all. Is anyone else seeing this error>
  • dyjofe09dyjofe09 NVPosts: 1 ✭✭✭✭
    Me too! I read that resetting will address the error. As for an updated version I am very skeptical...
  • gxjenkinsgxjenkins Tampa, Fl.Posts: 4 ✭✭✭
    Thanks, dyjofe09.
  • jasonscarterjasonscarter United StatesPosts: 1,961 ✭✭✭✭✭✭✭✭
    The update servers are offline...there are posts about this already in the community.
    Thanks, it looks like this has been happening off and on since 2016.
  • lettymaria904lettymaria904 United StatesPosts: 2 ✭✭
    Still having issues. My phone has gone completely crazy. I have cleared the cache, did a factory reset, uninstalled apps, keep my storage at a certain level. It's really messing up. Haven't had this phone for even a year and it's giving me so many problems. What else can I do. Don't exactly have the funds for a new phone.
    If you are unhappy, get a new phone. Understand about lack of funds but that's the solution. Look for used deals on swappa or something.
  • JabbaJabba CanadaPosts: 1 ✭✭✭✭
    As near as I can tell, the error occurs because the app 'Android System Webview' is either disabled or not updated.  Hope this helps.
  • AlciusAlcius HaitiPosts: 1 ✭✭
    • DFG
