Spro 2 remote apps gone?
jmdurajmdura United StatesPosts: 2 ✭✭
Hi, I really need the IOS remote app for the Spro 2 and it is gone from the Apple store. Can you add it back? Also the Play Store app is gone as well. Can you update this as well? Thanks!
  • jasonscarterjasonscarter United StatesPosts: 1,778 ✭✭✭✭✭✭✭✭
    This is like one of ZTE's only apps in the app stores, and they cannot distribute it because it contains USA based software/patents in it. All part of the export ban I suspect. It won't be coming back I bet.
  • jmdurajmdura United StatesPosts: 2 ✭✭
    https://www.theverge.com/2018/7/3/17532508/zte-ban-us-temporarily-lifts-security-updates
    Maybe with this announcement of the US lifting the ban then the apps should appear back in the app stores. Even if they could just put the the apps back up this month it would help with supporting the spro and we would be able to download it from the Apple app store. If there is someone here that could relay this to the developers then that would be very helpful.
