**UPDATE: Blade Z MAX B25 Now Available**
2»
    My Z982 notified me today of the update, and I have installed the B25 Build.
    My Android Security Patch Level is August 1, 2018.
    I hope to always use a ZTE phone.
    Keep up the Good work !! :)
    Seems like a lot of ZTE updates are a gamble. After having experienced the Blade V8 update, I'm gonna have to pass on this one for now.
  • matt_zteFan62matt_zteFan62 United StatesPosts: 20 ✭✭✭✭✭
    I have noticed a few inprovements after reset my phone from the update. I think mostly the update was more focused on the security, with I am happy about. Just hoping that now we will start to see them more regularly than normal. That's a hope!
  • syntapsyntap Washington DCPosts: 216 ✭✭✭✭✭
    I installed B25, update went fine. As a normal practice I factory reset on major updates, and though this one was not major I still did it because of issues noted by others and the amount of time it has been. Battery life seems as good as before.
    After factory resetting this morning, setting things up, disabling unused preinstalled apps (Facebook and its helper services, some MetroPCS stuff, unused Google keyboards), and charging back to 100%, it is at 95% power after seven hours. I'll take that!
  • VictourVictour United StatesPosts: 2 ✭✭✭
    @hollap said:
    Downloading now and installing now.
    How do I download this, Again?
    If you haven't already gotten a notice, you can go to settings->software update->check for update
  • scan718scan718 United StatesPosts: 65 ✭✭✭✭✭
    Thanks hollap. I was having lots of freezes after the update. uninstalled Zedge, and back in business. i left the Zedge folder with my wallpapper. Done with zedge
    You're welcome!
  • milly200milly200 United StatesPosts: 1 ✭✭
    Is anyone having wifi connection problems? I can't connect to any wifi anymore. I factory reset thinking it would solve this but nothing. Reset it 2 times now. Wifi just says disabled after entering password. I have tried to input it manually too. Help?
  • QuasariiiQuasariii United StatesPosts: 1 ✭✭✭✭
    Where can I download this
    @milly200 so you see wifi networks available but cannot connect? You could try a network settings reset. Go to settings->more->Network Settings Reset Might help.
    @Quasariii Settings->software update->check for update
  • MarkyJ64MarkyJ64 United StatesPosts: 1 ✭✭
    Ok, since this "upgrade" to build 25 I can no longer connect to my home Wifi. Every other device in my home, from my tablet to my printer, connects perfectly. Not this phone. I went back to the PCS store and the girl there told me that because the phone connected with the Wifi in store that there must be a problem with my Internet and that I needed to contact Spectrum. How does a failed update to my phone cause me to need to have anything to do with my Internet provider? Especially since the problem started after this supposed upgrade? Using the Finger app on my tablet I an see every other device connected to my Wifi, but not my phone. Kinda narrows it down, huh?
    It sounds to me like one of the "security enhancements " has caused my phone to reject my wifi. What can I do???
    Pretty frustrated, as I had been very pleased with the phone and service up to now.
    edited October 11, 2018 8:40AM
    @MarkyJ64 you can try doing a network reset by going to settings->more->network settings reset. Keep in mind this will reset Bluetooth, Cellular and wifi data.
    Are you able to connect to public wifi at all? Also, is your home internet running 2.4gHz or 5gHz? The Blade Z MAx only supports 2.4gHz.
  • TasukiFBTasukiFB United StatesPosts: 1 ✭✭
    edited December 5, 2018 11:29AM
    My ZTE Blade Z Max is still garbage even after update.......I own 4 and 3 of them won't unlock and I've had service on them over a year with metro but it always just tells me server not responding I've never been able to unlock them I've even left metro stumped and customer support and have done mulitple resets. I would understand if it was just one bad device but all 3? The forth one made it successfully but thats because it was unlocked first when it was bought way back when and it only had Android 7.0 and after 7.1.1 it stayed unlocked the other 3 we're upgraded to 7.1.1 before trying to factory unlock and from then on could not be unlocked ever so this is an issue ZTE has failed to address for over a year now. It's not a user error because I've tried everything trust me.
  • lverde835lverde835 United StatesPosts: 3 ✭✭
    I made a software update (B25) in my zte z982, then when restarting the wifi does not connect, level of the security patch August 1, 2018, compilation number Z982_MPCSV1.0.0B25, I already made a reset of the cell phone and still not can connect to wifi.
  • SNAGLETOOTH32SNAGLETOOTH32 United StatesPosts: 6 ✭✭✭✭
    How about a blade z Max 8.0 update?
    @SNAGLETOOTH32 I've mentioned it a few times in a few different threads. The Blade Z Max will no longer be supported.
  • serenity13579serenity13579 United StatesPosts: 1 ✭✭
    Please help.... The box that allows me to update my phone won't allow access to the update button what do I do....
    @serenity13579 You may be able to shrink down your display size in the settings.
