When is the update going to come to my phone I have not gotten any updates where I can get the update 8.1.1 it's not Fair that everyone else has it and we don't I've had this phone for 6 months waiting on the new update and so far I'm not getting it really not happy
hi, Dian
This update is security update and not platform update. If you go to setting-->About Phone-->Build number, you will see what is your current build. If you are running the latest build, you can also go under Setting-->Software update to check if there is newer update available. Blade Z Max is currently still running Android 7.1.1 and so far there is no information regarding Oreo update. As always, carrier branded device depends on the carrier for the update.
I had hoped the ZTE Blade Max might get the Oreo OS Update, some users are saying its not going to happen on these under $200usd on metropcs carrier. shame that, im sure they would rather sell me a flagship fone with Oreo or the newer Pie OS - well metropcs if i cant get the Oreo OS update over the air installed Im not buying a flagship fone to get the better OS be it Oreo or Pie #LuvMyBladeZMax #MostBangForTheBuck
@HouseCt said:
Says August 1st still.
I have been going to mine and checking frequently but nothing here either 😏
How can I tell if I got the B20? It only shows I have Android 7.1.1
@Gandolf go to settings
All the way to bottom "about device"
Go to bottom look at build number
The last number B20 is the most recent.
I don't have it either it really makes me mad hope we get it sion
hi, Dian
Thanks so much keep me updated on this update thanks
Tired of all this with the phones
Oreo is not available for the 982. At this time there is no further development for the device.
