I just spoke with a customer services rep for zte usa and she stated that at this time and in the future they don't know if they are going to be getting any cases for the blade max view. she told me to try vendors and if they get some they wont when that will be.
Thanks ZTE for the lack of a case. Now my screen is cracked as well! The first phone I have ever owned in my life that had the screen cracked! Not very happy and unlike some other posts here I will not be purchasing another ZTE....ever.
@Btyhntr Give customer service a call and let them know the situation. The last I heard was that the repair on the Blade Max View was less expensive than most.
the alcatel 7 case fits the blade max view almost perfect i had to cut out alittle around the volume power switch tho
Just bought the phone again, I have the worst luck w/ phones tho. Just gonna get any case I can that will fit
get the note 8 plus case or the alcatel 7 case. you are going to have to modify it but it will give it some protection
Will this work?
https://tudiaproducts.com/products/heavy-duty-dual-layer-merge-case-for-zte-blade-max-view?variant=26486857433188&utm_medium=cpc&utm_source=google&utm_campaign=Google%20Shopping&gclid=Cj0KCQjw4-XlBRDuARIsAK96p3DXVgjcWINnDBL281I49J23JHf7kTU6JAtxrrS3d7-4Gr47-bD_OAgaAvLoEALw_wcB
Rlruatti Indeed it will!
