I just did the update last night ..works great so far!
After I updated it... I performed another factory wipe just to ensure everything would be smooth... although I'm sure it would have been wiped anyways during this upgrade process...my OCD kicked in lol!
I have not experienced any Dolby Atmos issues.
Good thing is, as another member chimef in... You can always go back to official nougat 7.1.1 if you want too!
Considering that ZTE has been pretty radio silent about the Axon 7 since the latest update, and the fact that the Axon 7 is now almost 3 years old, I would say it's unlikely... But they were radio silent before the latest update launched, and if they are willing to bring in another update to add functionality, then awesome. Either ways I'd have no real complaints
Only issues I have is that I can't sync up one online email address (an @mail.com account) and that my other emails don't update unless I go in there and refresh manually. No clue what's up with that but it's getting annoying.
If i can get my emails working again, I'd say it's worth the hassle...
My son has been using this phone so I now decided to install this oreo. I hope that the are going to continue with some updates for stability and especially security. Android PIE would be nice at this point.
Now that I have been running Android 8.0 official oreo…. works great by the way.
I managed to pick up a dirt cheap Google Daydream View 2 headset ...so just to experience that I want to downgrade back to Nougat 7.1.1 official.... I have the both versions (8.0 and 7.1.1) on the root of my sd card...
I went to try and install 7.1.1 from the sd card by turning off the device and holding the power button and up button key combo..got the expected android menu... when I went to choose update from sd card thinking I could just choose the 7.1.1 version on the card like when I upgrade to oreo...I get an error msg from the ZTE indiciating "Sorry, OEM unlock not enable. Can not update from SD card."
Yes using official 8.0 Oreo currently and have the B35 7.1.1 which I'm trying to install...
I figured out the issue in case any one has the same problem.... both are my sdcard files are official ZTE firmwares Nougat 7.1.1 B35 and Oreo 8.0 official….in order to downgrade I had to go and activate the developer options menu in settings and change the setting for OEM unlock to enable..once I did that I powered off the device and was able to downgrade from the official ZTE Nougat 7.1.1 oem ….the phone has never been modified in any way...and always on official builds.
Sucessfully downgraded back to 7.1.1 B35 and going to try out Daydream...I got the daydream View 2 2017 headset for dirt cheap :)
It just reset Wifi, BT, Cellular settings. You need to reconfigure them (prob not cellular). Not sure it will help but worth a try. Sometimes network issue can be sim related, if you happen to have another sim to try, maybe worth to give it a test.
Anyone tried this update work for Axon mini. I tried but I get error 3004 and states “that this update is for alisa i and this is tulip.Installation aborted.” Not sure what this means.
this is only for Axon 7 and will not work for the Axon mini since the hardware underneath the phone are different. Flashing it will in fact brick the phone (ie render it useless).
Network settings did not help. I am using a different SMS app than I usually use to make sure it's not the app. At some point, messages simply won't sent/delivered.
You can get a small SD card for a couple dollars, do the upgrade and throw it away if you really don't want it. Or borrow one from a friend. It's not that big a deal.
So what you're saying is.... you can't be bothered to buy a $2 SD card just long enough to do a major update to your phone on the PRINCIPLE that you spent extra money for onboard storage?
That's like saying you bought a PC with tons of RAM just so you never have to use a hard drive, and then you get stuck the first time you have to reboot.
Hello z community im new here. I just bought axon 7 recently and yes all update has been done via ota and i see alot of video tutorial on how go upgrade to android 8. My question is can i just skip android 7 and direct update to android 8? Hope y'all can help. Or someone already done this? Skipping android 7..
Cheers
That's a good point. It's not as if I am stuck with the new like an apple 😂
I would say they are done with updates on the Axon 7. I may be wrong but I thought they said as much in one of the threads here.
Random Question In the wrong room but... Does anybody know if this will work on an Axon M? I'm desperate lol ...
This update is not compatible with the Axon M.
Did the update and everything went smoothly.
Hey all,
any help would be appreciated friends!
cheers
Are you using the official oreo firmware from zte's site (https://www.zteusa.com/support_page?Enter+Model+Name+or+Number=AXON+7) (go to to Resource-->select product to find the firmware-->B35).
cheers all
Anyone else lose Cell data all of a sudden?
Out of the blue, every few days, Cell data is gone and nothing other than reboot brings it back. Extremely annoying.
Anyone else have this issue?
have you tried to reset the network setting?
I did not. What does it do? Will I need to reconfigure anything?
Hello. I'm getting a cant mount sdcard error when I try to update this software from the boot menu. Is there an easy fix to this error?
Just get the SD card and stop being difficult.
It's not even worth updating at this point, The phone and software is SO far from it's prime you're better off just upgrading to a new phone.
this support ZTE axon7 G model?
Unfortunately, this is only for the 2017U model and not the 2017G or Chinese Models.
There is a Oreo update for the 2017G , I'll look for the link and posted it on here for you or anyone to download.
Edit :
Here is a link where you can check for your Region and device.
https://www.ztedevices.com/en/support
你们好.我的手机是zte b217g_usav1.2.ob14,是否可更新?请指教。多谢!
你的手机不是美国版的axon 7,所以不可以用这个软件来做更新。
请问还有什么软件更新?
