M mod
betasetabetaseta TurkeyPosts: 1
axon m
Extended mode and dual mod not working
    hi,
    can you let us know a little bit more detail on the issue.
    Is second screen working at all? Can you use AA mode (ie mirror screen mode where you see the same thing on both screen)? If the second screen is working, then it is most likely a software issue.
    Though, if you are are not able get anything on the second screen, then there is a possibility that it could be a hardware issue.
  • Mercadobige2015Mercadobige2015 United StatesPosts: 7 ✭✭✭✭
    I'm having the same issue intermittently at first but not I can't get my 2nd screen to work at all in dual & extended mode only.
    Definitely confusing and more so frustrating as those are the most important modes to this phone and main purpose of the 2nd screen.
    The screen will function in the mirror mode (A/A) but it won't give me the option to select the other two modes at all.
    Someone please help.
  • mblackmblack United StatesPosts: 4 ✭✭
    Me too, same problem. AA only thing working. Kinda a drag considering that's the whole point of this phone.
  • NOUAMENOUAME United StatesPosts: 2 ✭✭
    J"utilise zte axon m z999, à chaque temps que j'accede au deuxième écran, l'appareil se redémarre de soi même. Aidez moi à trouver une meilleure solution
    J'utilise zte axon m z999. À chaque temps que j'accede au deuxième écran, l'appareil se plante et se redémarre de soi même. Aidez moi pour une solution rapide
