Case for Blade Max View and clock-weather widget
dickie49dickie49 Austin, TXPosts: 13 ✭✭✭✭✭
Just received my new Blade Max View, and cannot find a clock,time, and weather widget for my home page. Does anyone know the answer to these two questions. So far, I'm not too impressed with this phone. But, time will tell.
  • samsamhasamsamha United States Posts: 2,330 ✭✭✭✭✭✭✭✭
    FYI, I do not have this particular device. However, typically with most Android phone, you long press the homescreen and then tap on widget . There you should be able to find both the clock and weather widget.
  • dickie49dickie49 Austin, TXPosts: 13 ✭✭✭✭✭
    Immediatly tried that, and it doesn't have any widgets for that
    A stock weather widget is not available on the Blade Max View. You may be able to find one within the Google Play Store.
    Thanks. Can you get them free?
