How do I mirror cast on my site blade
1twism1twism Winter havenPosts: 1
I would like to know how to mirror my phone on my tv .do I have to have my phone rooted or not or do I have to have internet at the house to do it cause I can mirror off my girls Samsung phone and it works with no problem but when I try it with my phone it don't work and I wondering how do I get it to work and no I don't have wifi at the house is there any way I can do it using my internet off my phone
  • razor512razor512 United States Posts: 2,583 ✭✭✭✭✭✭✭✭
    To cast your display, open your android settings and then do the following:
    1: Click on display
    2: Scroll down and then click on "Cast"
    3: Turn cast on and let it scan for displays on your LAN. (you must be on WiFi)
  • samsamhasamsamha United States Posts: 2,007 ✭✭✭✭✭✭✭✭
    Just want to add to what @razor512 has mentioned, the TV and the phone also would need to be on the same wireless network as well (Blade Z Max supports 2.4GHz band so make sure your TV is also on the same 2.4GHz band and not on a 5GHz band). Sometimes the phone will see the devices connected to the 5GHz band of the router but you won't be able to cast unless both devices are on the same band.
  • epaigeepaige United StatesPosts: 2 ✭✭
    Why would they make a hi end ZTE blade x max and no wifi display a $200 phone really
    I WASTED my money Cricket won't take it back even though it's brand new had it for. 8 days said I miss the free return day by 1 day don't know who's worse. CRICKET OR METRO PC. IF YOU TALK ON METRO PCS PHONE FOR 1 HR TALK TIME THEY WONT GIVE YOUR MONEY BACK NEVER HEARD OF A DUMB **** BUSINESS MOVE LIKE THAT BUT ITS ON THEIR RECEIPTS HOW YOU SUPPOSED TO LEARN HOW TO USE IT
