Axon M Screen misalignment.
theritz49theritz49 JapanPosts: 1
Just got a new axon m from ebay. Found out that the secondary display is placed a bit higher than the main display. May be 0.Something mm. Once i noticed it, it feels a bit frustrating in full screen mode(unfolded) as images or texts are a bit above in the secondary screen. This may be an assembly error or quality control issue. Just wanted to know if others have the same issue or is it just me? Should i return it?
Display top photo:
https://photos.app.goo.gl/mDLydJQmJwuee9Qt8
Display bottom photo:
https://photos.app.goo.gl/bHbzjiPcmpdabRaJ6
  • samsamhasamsamha United StatesPosts: 2,218 ✭✭✭✭✭✭✭✭
    i have seen this too on the unit. This is a bit more annoying when you have app spanning across both screen in horizontal position, and it is a bit less bothersome when the phone is placed vertically.
  • JaydatekJaydatek james dixon American SamoaPosts: 27 ✭✭✭✭
    it's most likely a refurbished unit.
