Telephoto or Wide Angle 📸 [Closed]
sshasansshasan Staff MemberUnited States Posts: 4,071 admin
edited July 29, 2019 6:57AM in Blog
Telephoto or Wide Angle... Which lens option do you use more often when taking photos with your smartphone?
Telephoto or Wide Angle 📸 [Closed] 18 votes
Telephoto
16% 3 votes
Wide Angle
83% 15 votes
  • DrakenFXDrakenFX Mobile United States Posts: 2,075 ✭✭✭✭✭✭✭✭
    I'll have to admit, I use wide Angle bit more than Telephoto, but I also use Telephoto in several several occasions 😅
  • fzrrichfzrrich United States Posts: 4,254 mod
    I use both however I have found that the wide angle lens is something I use more often and really appreciate having in a smartphone.
  • samsamhasamsamha United States Posts: 2,281 ✭✭✭✭✭✭✭✭
    I also feels that wide angle is probably more useful than telephoto in day to day use.
  • saeedtedsaeedted United StatesPosts: 1,212 ✭✭✭✭✭✭✭✭
    I use the wide angle lens more on my phone. The telepohoto lens is mostly used to for a portrait mode effect.
  • mrknight85mrknight85 United StatesPosts: 649 ✭✭✭✭✭✭✭
    Never use telephoto always use wide angle if the devices has it love to capture as much as possible.
  • DoppelgangerDDoppelgangerD Master Of Ceremonies United States Posts: 1,844 ✭✭✭✭✭✭✭✭
    I like having both (any flagship model smartphone should have both in quality form), but I probably use telephoto more, so I'll vote for telephoto. As usual, the odd man out...
  • austin45austin45 United StatesPosts: 200 ✭✭✭✭✭
    I always use wide angel whenever I can.
  • dnewman007dnewman007 United StatesPosts: 3,643 ✭✭✭✭✭✭✭✭
    edited June 24, 2019 5:53PM
    Like most here I tend to use wide angle more than telephoto. Availability of both is nice to have.
    I never use telephoto just because the Lost of picture quality I like my pictures to look a crispy as possible 😁
  • runtohell121runtohell121 Analyst United StatesPosts: 2,250 ✭✭✭✭✭✭✭✭
    Wide angle; currently have the S10+ and been using the wide angle quite more often than the telephoto.
  • ironbaybeedollironbaybeedoll United States Posts: 4,623 mod
    I definitely think both are needed and fit a purpose. I don't feel phones handle photos well in telephoto modes.
  • jasonscarterjasonscarter United StatesPosts: 1,892 ✭✭✭✭✭✭✭✭
    Wide angle for sure. Or be the phone that just doesn't care and puts like 50 cameras on the back with every possible option!
  • wings4anniewings4annie United StatesPosts: 1,408 ✭✭✭✭✭✭✭✭
    Wide angle for me!
  • tommytomatoestommytomatoes United StatesPosts: 12 ✭✭✭✭
    Wide angle so I can fit more in the picture.
    Both have their uses, though I find wide angle to be more useful. The issue with telephoto is that you will often see something like a 2X telephoto which does not offer enough zoom to justify its price. In such a situation, users would be better served with a main camera unit that has the extra money go into a larger sensor.
    Getting something more like a 3-3.5X zoom would be better as that will cover the most basic zoom range covered by many mechanical zoom cameras and DSLRs where you effectively get an 18-55mm equivalent range.
    Compared to needing zoom, I find myself needing wide angle more often,. One thing I would love to see in a smartphone is a wide angle lens and the same sensor as the primary camera, along with OIS so that wide angle can be used in a wider range of situations.
