[Tech Tip] Beat The Summer Heat
sshasansshasan Staff MemberUnited StatesPosts: 4,015 admin
This summers hot weather can cause our devices to malfunction, here are a few easy tips to prevent that from happening.
- Keep your device away from direct sunlight
- Kill any unused apps or put device in airplane mode
- Remove your device from it's case to avoid trapping heat if your outdoors for an extended period of time.
