Rotating Projection 90 degrees
I'd like to rotate the projector 90 degrees. Is this possible? Auto rotate seems to work on the display screen perfectly but the projector only displays horizontal images and flips them 180 degrees.
  • Ya, I noticed that, too when I first bought it. There were a few apps I like that only seemed to work in portrait, resulting in displaying the interface sideways on the Spro's screen, and was further disappointed that I don't see an option anywhere to get it to project it in the correct orientation. But, I don't know if something changed, other than me installing apps like Nova Launcher Prime (which replaced the Spro's home screen) and Ultimate Rotation Control, but I'm getting portrait projection now. Still, would be nice if there was a specific option in the Projector Settings applet.
  • ironbaybeedollironbaybeedoll United StatesPosts: 4,614 mod
    ​ Good Evening. The Spro2 definitely doesn't allow you to rotate 90 degrees when in projection mode. Hopefully this clears things up
