Stock Android Dialer
Hey guys, I was trying to download the stock Android 6.0 dialer through an APK. I was able to successfully install this km my LG style 2 Plus,  but I am unable to on the Blade V8 Pro. I have the option for downloading apps from unknown sources turned on. What else can I do to make it work?
  • It says "App not installed" when i got to install it.
  • It is in my download manager, that is where it tells me that the app can't be installed.
  • DrakenFXDrakenFX Mobile United States Posts: 2,111 ✭✭✭✭✭✭✭✭
    Instead of using the download manager, use the Filer Explorer and try Installing it from there.
    P.S. the dialer is the "nodpi" version right?
  • I tried installing it through the File manager and still doesn't work.  I have downloaded atleast 8 different types of stock phone dialers and none of them work.  I have been able to download other apks with no problem though.  I am not sure if the dialer is the nodpi version.
  • I can't, it can't installed,  that's what I'm trying to do is to install it.
