Hey ive been searching around the web and for a case and a tempered glass and im not able to find any at least not yet. I wanted to know if anyone knew a tempered glass that could fit for my blade v8 pro at least so it can be protected until the originals come out.
is the screen curved like the axon 7??
Yes , the Blade V8 Pro has 2.5D curved glass.
I dont think there is a perfect screen protector for curved glass. Im still searching for one to fit my axon 7 without lifting on the edges. so far the one in the box is doing ok but I can see it lifting already. I'd suggest looking on amazon and reading the reviews.
it has a slight curve not much. so basically i can use the axon 7 tempered glass then?
I am a glass screen protector kinda guy as well . I just live them. I haven't been able to find anything that looks like it will fit well so I decided to order the delta shield from Amazon. It's a 2 pack with a lifetime warranty. ZTE Blade V8 Pro Screen Protector [2-Pack], DeltaShield BodyArmor Full Coverage Screen Protector for ZTE Blade V8 Pro Military-Grade Clear HD Anti-Bubble Film https://www.amazon.com/dp/B01N5R9PIE/ref=cm_sw_r_cp_apa_84zLybVRSM3BP I'll be sure to let you know what I think about it.
I had one of those on my axon 7. It would have worked better had I not used a case on the phone.
I use the spigen case on the axon and it grips around the curves of the glass which manages to push up the film. I ended up removing the film and rocking the bare screen.
I really wish this curved glass fad would pass. I feel naked without a screen protector on the phone. But luckily, no scratches yet.
I know how you feel. I can't not have something protecting my screen. I still have the original plastic protecting the screen on my Blade until the screen protector comes in. I know what you mean about cases interfering with things, I had a slick wrap on my Axon 7 and the case for so tight and came so close to numerous spots of the wrap it would keep getting caught and lift up, I had to eventually remove the slick wrap. Didn't help that I kept trying different cases all the time too I'm sure lol. I'm hoping that someone eventually makes some decent glass screen protectors for these phones with curved glass. I don't like that the ones available have to be placed in the center with something like a 1/8th of an inch gap around the perimeter. I'm getting used to it on my Axon 7 but wanted to try something different that covered the wheel screen on the Blade.
I tried a glass protector on my Axon 7, and I hated the way it came short of the edges. I bought the Delta Shield and I think it was as good as it will get for this type of screen. Not as nice as glass, but much better than the cheap plastic protectors.
I'm on the same boat as you guys, but I've had a number of phones with curved display and haven't ever found a company that succeed on this promise without bubble edges and halo effect. I decided I'm going naked in these types of phones but at least want a case for it at bare minimum. I haven't been able to find a nice clear thin TPU case yet for the v8 pro.
I wonder if anyone has tried these...
Its totally possible to make a 2.5d tempered glass protector that will work with a curved display, in fact there has been a bunch for the iphones, S7 samsungs and my Zmax Pro which all works with the curved display.
i think i might need to try those because those are by far the best fitting ones for this phone
Amazon.com: ZTE Blade V8 Pro Case, Starshop Hybrid Heavy Duty Rugged Impact Advanced Armor Soft Silicone Cover With [Pre…
